ActiveX for USB microscope
I'm acquiring images with a DinoLite USB Microscope using LabView. It works with ActiveX, specifically DNVideoX. I'm able to save a picture, but I need to convert the picture obtained with DNVideoX which is in variant type, because with this type I can't work. I need to calculate the pixels between two point of this image. The software that I have for the moment is attached.
Thank you.
(4,050 Views)
I think you'll need to research to find out what kind of data is returned by "GetRGB". My guess would be something like a 3D array, 2Ds for the camera sensor, 1D to represent red, green, or blue.
(4,012 Views)
Also, you can just put a probe or indicator on it and it should give you some hints of what the variant looks like.
(4,011 Views)
