ActiveX automation open returns "Not enough storage is available to complete this operation."
I'm trying to call the software that comes with a testing instrument. The program supposedly can act as an activeX server. So I use automation open in labview to call it. I could see the program launched, but then it closed quickly. The error returned by the automation open was "Not enough storage is available to complete this operation." Is this because I don't have enough RAM (64 meg) to perform this operation? How come this program could be launched with no problems using Visual Basic?
(2,954 Views)
The new NI Office toolkit uses ActiveX and I ran into the same error message and odd behavior recently. The problem that I had was regarding MS Excel and I have 128 MB RAM on my computer.
I was calling several Excel VIs at a time. What I ended up doing is changing the way my program calls these VIs and ensuring that only one VI is called at a time by wiring the Error Clusters together to create data dependencies.
Hope that helps.
(2,954 Views)
