ActiveX WebBrowser in Executable
I placed an ActiveX Control WebBrowser in my Application to display the remote panels of different VIs which run on a realtime system.
In the Development Environment everything works fine. But when I build an executable I first get a popup message which says that the webserver cannot be started. Just a second after I get a message of a fatal internal error ("LVClient.cpp", line 271...") and the application crashes.
I tried different settings in the application builder but nothing helps. Without the ActiveX control I don't have that problem. I use LV 8.20 and WinXP.
thanks for any help!
Dave
(2,789 Views)
Hi Dave,
The first message is while the exe run and the LabVIEW lauch also the Web Server...
Try to uncheck the Enable Web Server in LabVIEW and try again...
Let me know the results...
Matthieu
(2,771 Views)
