ActiveX Treeview and ADO efficiency problem
I am using Database Connectivity Toolset (VI compatibility), and an
ActiveX TreeView control in LabView 6.1.
As soon as the TreeView is filled with data (a large amount), every
query will slow a bit (for example after a day the delay goes from 3
secs to 14 secs). It seems a sort of interaction beetwen the two
ActiveX (ADO and TreeView). When the TreeView is closed (stopped the
VI that uses TreeView) the query run fine, but even closing the
TreeView, it's not so efficent as the first time. So it seems that
efficiency decrease while using the TreeView, even after closing and
opening again the VI with the TreeView (not the VI with the query). If
one exit from LabView efficiency is again good.
The Database is Oracle but this is
not important.
Using the old SQL toolkit everything works fine.
Has anyone already had this kind of problem?
Thaks in advance
Beccarini
PS: Win2000, sp3, oracle9, LabView 6.1
(2,950 Views)
This is definetly a memory leak. NI's TreeVIEW example is not a good one.
E.g. when you use "selected node" every MMI loop, each time it returns a new
value! Even if the selected node has not changed! This is how ActiveX works.
The Nodes property will return a list of different references to the same
objects each time is is called!
The Item property will return a different references to the same object each
time is is called!
The Parent property will return a different references to the same object
Close Everything! Closing a reference does not mean that the object is
deleted, but that the *pointer to the copied information to use this object*
is removed. Well, don't close the reference to the container, but that is
the only ref that should not be closed.
Be aware on for loops. E.g. "Nodes" is a reference. Use "Item" and "Index"
to loop "Count" times, and in the for loop close the "Item". Wire the
"Nodes" after the for loop. But what if "Count" is zero? The for loop runs
zero time, and the output ref is zero. So, use a shift register, or rewire
so that the "Nodes" ref
Wiebe.
"Beccarini" wrote in message
news:b8e80143.0212030343.73d36e16@posting.google.com...
> The Database is Oracle but this is not important.
> Thaks in advance
> Beccarini
(2,950 Views)
Thanks a lot Wiebe,
I am going to try it and I am pretty sure the problem is what you
wrote below, because I didn't close any reference.
Thanks again,
Andrea
"Wiebe@AIR" wrote in message news:<3decc470$0$75596$e4fe514c@dreader3.news.xs4all.nl>...
> Hi,
> time is is called!
> Regards,
> Wiebe.
> > Thaks in advance
> > Beccarini
(2,950 Views)
Good luck!
Wiebe.
news:b8e80143.0212160828.25593d67@posting.google.com...
> Thanks a lot Wiebe,
> Thanks again,
> Andrea
> > Hi,
one.
new
works.
same
each
> > time is is called!
object
object*
is
"Index"
runs
rewire
> > Regards,
> > Wiebe.
> > > Thaks in advance
> > > Beccarini
(2,950 Views)
