ActiveX ADODB LAST_INSERT_ID() returning zero
Hey everyone,
I connect to a MySQL database using the Microsoft ADODB ActiveX classes (ADOBD.recordset). This works fine for basic SELECT, INSERT, and UPDATE MySQL commands, and I'm sure others that I haven't tried yet. The table has an auto-increment, unique identifier column named 'id', and I'd like to return the last value that was inserted to the table. However, running SELECT LAST_INSERT_ID() returns a 0.
I've looked into it, and some people mentioned that the ADO can't handle BIGINT, so I've added "Option=16384" to my connection string (FLAG_NO_BIGINT) and still no luck. Others mentioned that the AUTO_IS_NULL database option is causing issues, so I tried that too and it still didn't work.
I also tried the command "SELECT LAST_INSERT_ID() FROM table" and that returned an array of 0s, with length equal to the table length. This is closer, but because items can be removed from the table, I can't use it for my purposes.
Does anyone have any other information on this?
On a related but much less important topic, can ADODB.recordset execute multiple queries or commands with one call? For example, sending multiple INSERT commands.
(3,544 Views)
Accepted by dthor
Have you tried something like:
select max(my_id_field)
From my_table;
Alternately does mySQL support the new SQL standard "returning" clause in inserts?
On your related question, you don't need a recordset to send a command. Use the connection execute method when you aren't going to be returning data. In terms of queries, the answer is yes but with qualifications.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,543 Views)
Excellent, thank you mikeporter. It's so simple, that must be why I couldn't figure it out. Since I won't be inserting to any index other than the last, this works wonderfully.
Regarding RETURNING, it looks like MySQL 5.1 doesn't support it, but PostgreSQL does (the other database system I use), so that's good to know.
Thanks!
(3,537 Views)
