‎02-24-2014 03:11 PM
And with that I can implement a scale for each channel? I will give this a try and see if it works.
‎02-24-2014 06:42 PM
@crossrulz wrote:
You want something like this...
Nope. That didnt work. It throws some error that I need a custom scale setup (even though I already have custom scales setup). I couldnt get the Indexing to be enabled on the tunnel loop (it was greyed out), so that might have had an effect on this. I'll give it another attempt tomorrow.
‎02-24-2014 07:40 PM
Attach your VI so we can see how you set it up. I don't see any reason why your tunnel would be greyed out, unless your scales control is just a scalar rather than an array. Did you populate the scales on your front panel control with scales from your system?
