Active/Enabled Channel Control
And with that I can implement a scale for each channel? I will give this a try and see if it works.
Message 11 of 13
(552 Views)
@crossrulz wrote:
You want something like this...
Nope. That didnt work. It throws some error that I need a custom scale setup (even though I already have custom scales setup). I couldnt get the Indexing to be enabled on the tunnel loop (it was greyed out), so that might have had an effect on this. I'll give it another attempt tomorrow.
Message 12 of 13
(537 Views)
Attach your VI so we can see how you set it up.  I don't see any reason why your tunnel would be greyed out, unless your scales control is just a scalar rather than an array.  Did you populate the scales on your front panel control with scales from your system?
Message 13 of 13
(526 Views)
