Acquiring mutile signals using MCC DAQ in Labview (Error 10017)
Hello all,
I'm working on a project which requires me to acquire multiple singals from a MCC DAQ and I have tried a few differnet ways of doing this and cannot figure it out. In the attached file the top portion is the issue. The first waveform that I acquire works perfectly but when I duplicate it and try to get another it shows a read error and displays a spike and then flat line in the waveform chart. I'm not sure if it is with the for loop or what. Any suggestions would be much appreciated.
(3,120 Views)
Accepted by mjbrisen
Do NOT duplicate it. Use a single task with multiple channels listed - Dev1\ai0:1.
(3,111 Views)
Thank you!
(3,098 Views)
