Acquire and process multiple images
Hi, I am using a NI PCIe-1427 frame grabber and was trying with acquiring and processing multiple image continuously. To be more specific, how could I extract 4 images from a buffer and do processing on the 4 images? For examples, I may acquire 1000 images (or continuously), but need to extract 4 images everytime to combine as a single image before saving the final image (the combined). Thanks for viewing and commenting. I woild appreciate if there are any examples I could learn from too.
(3,260 Views)
Hi sp@davis,
Here's an example that combines four images into one image. And here's one that stitches multiple images together into one. I hope this helps!
David S.
(3,232 Views)
Hey David,
Thanks for the suggestions. Actually I referred those examples before. Is there anything which do continuously acquisition and processing?
sp@davis
(3,213 Views)
Accepted by sp@davis
Hi sp@davis,
Have you taken a look at this example that goes through the stitching and processing of a video stream? There are tons of other examples for various types of image processing on the NI Community (such as this one) if you have a specific type of processing in mind. Hope this helps!
David S.
(3,198 Views)
