12-05-2008 02:45 PM
12-05-2008 04:50 PM
I'm having some trouble understanding why you are removing the start time information and then putting it back in. Your waveform data type has a t0. Have you looked at using the Export Waveforms to Spreadsheet File?
Also, the wiring of the iteration terminal to an indicator, then using a local variable, then doing a comparison is silly. If you want to do something only on the first iteration, wire the iteration terminal directly to the case statement selector.
