Accessing Signal Express Sweep parameters from User-Defined Step (LabVIEW)
I'm a newbie to SignalExpress and just trying to set up a small demo. In order to implement a customized result logging, I need to have access to the parameters of a sweep "loop". I haven't managed to configure them as inputs for the LabVIEW module. (Yes, if've put it into the loop Smiley Wink)
Is it possible at all?
Cheers
Oli
(2,886 Views)
Hi Oli!
Signal Express 1.1.1 is compatible with Labview 7.1. Which versions do you have?
Please look at the following link:
http://digital.ni.com/public.nsf/websearch/90F9095308D9264D86256F320079B120?OpenDocument
Hendrik
(2,868 Views)
Hi Honsel,
I'm using SignalExpress 1.1.1 and LabVIEW 7.1.
Got it working in the meantime... it seems that for the first few tries, the LabVIEW Adapter of Signal Express "ignored" the sweep parameters. After several tries, its working....
Anyway, thanks for your answer!
Cheers
Oli
(2,865 Views)
