02-27-2009 09:13 AM
02-27-2009 09:39 AM - edited 02-27-2009 09:39 AM
The Application.UserName will return the user name used to open the application:
As for checking it against a list, where's the list coming from? Is it a file? A database? Someplace else? If it's a file you will probably read it into an array and you can then use Search 1D Array to see if the name is in the list (taking into consideration upper/lower case).
To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
02-27-2009 09:39 AM - edited 02-27-2009 09:41 AM
02-27-2009 10:23 AM
I just tried your suggestion in my application and it works great. I dont really understand it but I'll read up.
Thank you very much!
02-27-2009 04:18 PM
jmcbee wrote:
Take a look at the attached code, it is in 8.0. (Beat to the punch)
Yes, well, you still got marked as the solution, and got a Kudos to boot! I guess sometimes coming in second is better.
02-27-2009 04:45 PM
02-27-2009 05:07 PM
02-27-2009 05:38 PM - edited 02-27-2009 05:38 PM
smercurio_fc wrote:
I appreciate the comment. My comment was a tongue-in-cheek remark - not getting Kudos is not going to stop me from trying to help.
That's worth some Kudos 😉
