Access to chart histor buffer
Suppose I have a waveform chart with several thousand points accumulated in the buffer.  Now I realize I want to save
this data.  If I had planned ahead and used a waveform graph, I could easily do that.  But since I am stuck with the chart, what can I do?  I know the data is in the computer memory because Labview maintains a buffer for the chart.  Is there any way I can access that information?
(2,710 Views)
Pop-up on the terminal and choose
create >>> property >>> History (its at the bottom)
It will be an array of whatever datatype you are using (if using 1-d array of WF's then it will be 2-d)
Ben
(2,706 Views)
Sure enough, there it is.  Many thanks!
(2,699 Views)
