Access one specific control property inside an array of clusters
I have an array of clusters. The cluster is an integer and three strings. I need to be able to change the background color of the third string in just one row of the array. I don't think it's possible, is it? I've been trying but I don't see a way to do it. Thanks in advance.
PaulG.
Retired
Message 1 of 10
(5,360 Views)
It's not possible.  You cannot change VI Server properties of an individual element within an array.  If you change a VI Server property for something inside an array, it is applied to all array elements.
Message 2 of 10
(5,355 Views)
Accepted by topic author PaulG.
Aggreed!
Convert to a cluster of clusters or add a color box behind the string after setting its background transparent.
Ben
Message 3 of 10
(5,351 Views)
As a simple workaround, add a flat colorbox as an additional array element and make the respective indicator transparent. Now simply write a new color to the colorbox of the desired array element.
Array elements are not allowed to vary in properties, but for a colorbox, the color is the value, which is fine. 😉
Here is a simple example (posted here long ago). See if it makes sense. 🙂
Message 4 of 10
(5,347 Views)
Nothing better.
Seems that all the big ones are active this evening ...  😉
Chilly Charly    (aka CC)
Message 5 of 10
(5,333 Views)
@chilly charly wrote:
Nothing better.
Silly Frog!
Snapping at the low-hanging fruit while code is syncronizing with the server is standard practice while in the office.
It is nice to see your very anoying avatar jjmping up now and then.
Ben
Message 6 of 10
(5,325 Views)
Yes, without that silly searching for links and examples, I probably would have beaten Ben by a few seconds. 😮 😄
Message 7 of 10
(5,317 Views)
Ben a écrit :
Silly Frog!
Silly bear !
Don't look for excuses for wasting your time with trivial matters.
At last it's 10pm here, and my wife should be the only one to complain. In addition, I'm on vacation
Edit : I forgot ; Love you all !!!
Message 8 of 10
(5,312 Views)
A few big guns came out on this one. I'm humbled. I knew the answer but just felt a little lonely and wanted the attention. Smiley Happy
PaulG.
Retired
Message 9 of 10
(5,290 Views)
LOL! Smiley Very Happy
Message 10 of 10
(5,277 Views)
