yes, off course!! But I could not find the device which i have connected with the PC. Thats why i tried to access the same through device manager. Please help me if you have any soloution.
O..Sure. First i tired to get the required information through the Reistry key as you suggest. But under the USB tree, i found more that 20 sub trees and no one of it hold the information about the USB device (Code warrior) which i have connected. After that I tried to access through devmgr.dll, and tried its different functions to get the required info. But i am not sure which function i have to use to fetch the information.
I think devcon is going to be easier for you to use. Try it. For example, the command "devcon find usb\*" lists the USB devices. The command "devcon find *" lists ALL devices.
Can't take full credit for knowing about that utility. In this thread I suggested using that utility, and I indicated in that thread the original thread where I found out about that utility.
