Access denied for VI's remote control (property nodes)
Good afternoon,
I want to control a remote system. I used the exemple for the model customer/server. With property nodes, I can choose the remote computer, IP, VI's name (in spite of tapping into options). But on the remote computer, the access is denied. the property nodes indicate the remote access is not authorized. Is it possible to get the access by programming (it corresponds in the options, Web server, double check for the remote access in the Web server list).
Thank you for your answers.
(2,903 Views)
Hi gautierdufourcq,
On the Remote Computer, you probably need to go through the process of Configuring the LabVIEW VI Server to Run VIs Remotely.
Edit: Interesting how that was from the TestStand Help, but the LabVIEW Help also describes the process of Configuring the VI Server (pretty much the same instructions).
Milan
(2,885 Views)
