Access VI where errorexception is thrown
Hello everyone,
I am trying to follow an LV generated error (error_out cluster). My master machine gets the bundled errors of all slaves and displays the errors on the main UI. Looking at the errorcode I can identify the statemachine. The error happens in daqmx-start (-50103: DAQmx-start.vi:722003). I set probes at every case I use the it but the error is never thrown.
Is it possible to follow the error to its caller, since I am not always aware which VI labview calls when I am using the native VIs?
(2,669 Views)
No. You'd have to manually trace it back to the source.
I'd be surprised if the DAQmx-start.vi didn't include a full call chain. That call chain is your trace.
The reason you don't see an error when you open the VI could be because it's a clone... So opening the VI opens not the clone but the original, that probably doesn't even run.
(2,641 Views)
I found the error caller, but I had to follow every instance it might call as stated above.
(2,633 Views)
That is the consequence of choices that where made...
Is your problem solved? It would be hard to give further advice without knowing more about (or seeing) the code.
(2,624 Views)
You need to write an Error Handler that "traps" the Errors in the Slaves and "does something sensible" with it.  Suppose you want the Slave to exit (quit), but to notify the Master that it has failed (probably a good thing to do!).  Your Error Handler could look like the following:
  • Start by copying the Error (branch the Error Line).
  • Clear the Error (so the Slave will continue to work)
  • Compose a "Message" to the Master (I'm assuming you are using a Message-passing protocol, something like a QMH) saying, in effect, "Slave #N exited with Error XXXX and Call Chain YYYY".
  • Go to the Slave's Exit routine and exit.
(2,611 Views)
