About error -140
 I am a new user of Lab VIEW. I have a problum when i connect my keithley multimeter with labVIEW with GPIB port. it gives an error -140. What is it? and how can i resolve it? please help me.
thanks,
Message 1 of 8
(5,472 Views)
Accepted by Pawan Patidar
That is an error from the Keithley.
"Character data error"
The meter did not like something you sent it. Syntax error or something.
Check the Keithley manual with the string you are sending it.
Omar
Message 2 of 8
(5,460 Views)
Hi
thanks for your kind attention. Will you please check the error in syntax in the program attached because I am unable to find the function where the error will come from?
Message 3 of 8
(5,449 Views)
The error comes from the 'Write GPIB' most likely, I see that you don't specify the decimal sign of your string, I altere the string formatter to make sure it's a point:
Ton
My LabVIEW Ideas
Message 4 of 8
(5,443 Views)
Hello
First I would like to say thanks for your kind attention. The error -140 is solved but now it gives the error -410 at same place. What is it and how can we handle this error in the program.
Thanks and regards
Pawan Patidar
Message 5 of 8
(5,434 Views)
Have you looked in your Keithley manual to see what error -410 means?
Query INTERRUPTED
What does the Keithley manual say how one might interrupt or abort an action
So what are you doing to interrupt the query?
How are you commutating with the Keithley?
There are lines on the GPIB bus that can abort and take the  Keithley out of TALKER mode
Sending a *cls?
Sending a *rst?
Pushing front panel button on the Keithley during a query?
Hidden control char in your string like a ctrl-C
Might need to see more of your code.
Omar
Message 6 of 8
(5,422 Views)
Hello
I am not asking for the error 410 which is query interrupted instead I am asking for the error -140. So will you please explain about that error..
Message 7 of 8
(5,405 Views)
READ the Keithley manual!
@Pawan Patidar wrote:
Hello
So which is it -140 or -410
Ton gave you an explaination for the -140 error
Do you have a Keithley manula and have you read it?
Omar
Message 8 of 8
(5,401 Views)
