Abort Button Not Working
@RTSLVU wrote:
I find a "State Machine" architecture works for 99% of the programs I write.
Ugh!  While it's generally true that 'a <fill-in-the-blank-with-anything> architecture> can work in 99% of your programs', anyone who uses the same architecture 99% of the time is probably writing a lot of poor code.
Message 11 of 16
(1,009 Views)
Meh... 99% of my programs are data logging and instrument control.
A state machine is the perfect fit unless I need high speed acquisition, then it's a producer/consumer, but the consumer loop will probably still have a state machine inside it. 😛
=== Engineer Ambiguously ===
Message 12 of 16
(1,006 Views)
I would say that is only strictly true if 99% of your projects are 99% different from each other.  I would say that 99% of the time, generalization isn't the best thing.  😉
Bill
CLD
(Mid-Level minion.)
Message 13 of 16
(994 Views)
No sense reinventing the wheel.
Message 14 of 16
(970 Views)
@cy... wrote:
@RTSLVU
adding a timeout on those subVI may improve the responsiveness of the abort.
also wondering why: sequentially? race conditions?
Over use of sequence structures is a huge sign that the programer did not understand the "Data Flow" concept LabVIEW programming is based on.
Message 15 of 16
(967 Views)
Thanks for the replies everyone.  For some reason it started mysteriously working again. I'll return to this if there are any more problems.
Message 16 of 16
(942 Views)
