AVI-file with labview
Hi everyone!
I am currently working with labview 6i and IMAQ vision.
My program grabbs pictures from a Grabbercard and saves them as jpg-
files. Because i placed this function in a loop, i am basicaly grabbing
sequences of single pictures.
My question now is, is it possible with labview to create an avi-movie
from this sequence of single pictures after i saved them or even
better, can i somehow save them right away as an avi-movie that is
appended everytime my program grabbs a new picture?
Thank you for your help!
Martin Klein
Sent via Deja.com
http://www.deja.com/
Message 1 of 9
(4,228 Views)
I did something similar and ended up getting a java programmer to write me
java app which converts jpeg files to a quicktime movie or avi file.
wrote in message news:949a7p$6pt$1@nnrp1.deja.com...
> Hi everyone!
> Martin Klein
> Sent via Deja.com
Message 2 of 9
(4,228 Views)
Thanx. I found out that it's actualy not hard when you have IMAQ vision and
the avi.dll.
I have both now and it works perfectly.
regards,
Martin Klein
B & C Duffey wrote in message
news:Wlph6.130295$8V6.18458748@typhoon.tampabay.rr.com...
> > Hi everyone!
> > Martin Klein
> > Sent via Deja.com
Message 3 of 9
(4,228 Views)
Hi atsw,
             Iam also working in a similar application can u pls tell me how u accomplished it?
Message 4 of 9
(3,833 Views)
Hell Bharathindian,
I would suggest taking a look at the 'Sequence and Save to AVI' as well as 'Grab and Save to AVI' examples that are shipped with LabVIEW. You can access these examples in LabVIEW by clicking on Help >> Find Examples. Under the categories to browse, go to Hardware Input and Output >> IMAQ >> File Input and Output to find these examples.
I hope this helps.
Vivek Nath
Machine Vision
Message 5 of 9
(3,811 Views)
can someone tell me what hardware is needed to do something like this?
i want to work on my senior project and i want to use labview. i dont know what hardware to get, things to buy to make this type of thing work.
thanks
Krispiekream
Message 6 of 9
(3,807 Views)
Thanks VIVEK_N,
                             One of my problems is solved.Let me explain my full objective.pls help me how to go about it.My objective is to find the centroid of four markers,present in an image     individually .This i find by making the user click on a point on the four markers, i create four rectangular subsets of the original image and find centroid of each image and then superimpose them on the full imge after making coordinate shifts required.But this is fine for a static image..Now i need to implement it dynamically for a video in which each frame will have different centroid due to shift in marker position.Now , how do i track the centroid as the video is runnin by timin the program in such a way the centroid keeps shifting as frames run..pls help..
Im attachin what i hav done with static images
Message 7 of 9
(3,775 Views)
THE images are like this
Message 8 of 9
(3,774 Views)
Hello krispiekream,
There are a couple of things that you would need to acquire images and process them using LabVIEW:
1) A camera
2) Vision hardware that works with this camera and that can be used with LabVIEW
3) NI Vision software that enables LabVIEW to communicate with this hardware
I would strongly suggest taking a look at these links:
1) Choosing the Right Camera Bus
2) NI Vision Hardware
3) NI Machine Vision Software
This should give you an idea of where to start. I hope this helps.
Vivek Nath
Machine Vision
Message 9 of 9
(3,754 Views)
