ATE System
What is ATE System? When and Where is it used? How it is related to NI LabVIEW and NI Hardwares?
(6,229 Views)
ATE stands for Automatic Test Equipment. It is used when you want to perform tests under computer control. We here use LabVIEW as the programming language that control those tests and often use NI hardware as the test equipment.
p.s. Not a good idea to have your email address in a public forum unless you like getting spam.
(6,224 Views)
I have the following queries on ATEs:
  1. What are the functions of ATE?
  2. What are the building blocks of ATE?
  3. How does the ATE test the Device Under Test?
  4. What are the different types of test that the ATE has to conduct?
  5. What is a test specifically? Is it comparing the read value with limits are determining pass or fail?
(6,177 Views)
Ever use Wikepedia? Good place to start for basic questions such as this.
(6,165 Views)
That was more like an insulting response...anyway thanks.
(6,142 Views)
