ASCII to decimal conversion function
So what kind of problems are you encountering if you try to wire it as shown? it should work just fine.
You can either use "string to byte array" or typecast it to an array of U8. Same difference.
Message 21 of 48
(6,133 Views)
after conversion i will use that number for comparison of a range like
0 to 100 ===> sensor 1 data
101 to 200===> sensor 2 data
201 to 255 ==> sensor 3 data
and then it will be sent to a sensor gauge for display.
Message 22 of 48
(6,130 Views)
It seems you are now talking about a completely new problem instead of answering my last question. 😮
Can we assume that you solved the original issue? 😉
To select depending on the value range, you can wire the number to a case structure and define three cases according to the desired ranges.
Message 23 of 48
(6,124 Views)
Hi ehsa,
try the attachment. Type any char into ASCII string control...
Message 24 of 48
(6,122 Views)
i am attaching my VI.
you can see it and will syrely understand what i need.
 i want my converted number to connect to the node which is below waveform chart. ( where string to decimal number converter is attached). if i attach converted U8 array to it then there is an error because my comparison is based upon number whereas output of conversion is array
Message 25 of 48
(6,115 Views)
in my VI i dont require, " Make selection"  loop. if there is some lack in my explanation then plz do tell me. i will be really thankfull for help.
thanks
Message 26 of 48
(6,113 Views)
Hi ehsa,
"you surely understand" - no, we can't! You only ask (new) questions, but don't provide answers to our questions...
As you have been asked before: provide some sample data you're receiving from the serial port! When we see actual samples we can pin down how to convert those "ASCII bytes"!
Is the char that you get from the U8 conversion not ok?
Message Edited by GerdW on 06-12-2008 11:25 AM
Message 27 of 48
(6,112 Views)
ok, sorry for that
my actual data is only one byte. it gives 256 values.
here i am providing serial data scheme of my project
i am receiving data from 3 sensors in a controller.
that controller reads temperature sensor data and sends to serial using value of 1 byte (0 to100)
humidity sensor (101 to 200)
pressure sensor (201 to 255)
my all bytes will be (in bits) ( 00000000 to 11111111) == 0 to 255
Message 28 of 48
(6,087 Views)
Hi ehsa,
when all you get from serial port is just one byte then take that one single byte you get after the U8 conversion (& index array) operation. It's all you need!
Message 29 of 48
(6,082 Views)
after receiving data in single byte i will check it from which sensor it is and then i will send it to front panel display of that sensor.
there i am also checking limits of this data i.e. if i need temperature to 050 only then after receiving data >50 and <101 will send a constant to serial out.
if i am not clear still then plz plz ask me where i am not clear in explanation.
thanks very much
Message 30 of 48
(6,080 Views)
