AO & 8AI - sinchronization precisely
I have 1 AO (sine wave) and 8 AI (sin waves) (PCI 6052E). They are launched at the same time. The frequency of AO - 5kHz. Ther frequency of AI - around 5kHz. Problem - I need to set AO - very precisely at 5kHz, and I need to read data very preciasely. It is very important not to have any delays in reading and sending. I need to know the phase shift between AO and each AI.
If somebody can give me any ideas about it? I tried to look at timing and triggering, but either they can not be used  for it, or I used them wrongly.
Thank you in advance,
Anna
(2,979 Views)
Do you have DAQmx installed?
I've done some analog input triggering, and some digital triggering and it worked great with my M-series card, but only after using DAQmx.  Traditional DAQ (even using VIs supplied kindly from NI) had problems.
I don't know about synchronising different types of measurements at the same time (AI and AO together) but at least the rate and moment of each individual sample should be synchroniseable using a hardware-triggered AI and AO.  Getting the first input / output to synchronise properly might be more tricky......
LabVIEW version? NI-DAQ version?
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,969 Views)
LabVIEW 8.0, MAX - 4.1 (is MAX=NI DAQ?)
Anna
(2,963 Views)
It's always a good idea to look at the shipping examples. In this case Multi-Function-Synch AI-AO.vi is the relevant one. This is example works with the 6052E.
HOWEVER this is a single- analog input example that needs to be modified for multiple inputs. And since this board has only a single A/D, you cannot do simultaneous sampling.  At 5 kHz this may not matter so much and you may be satisfied with predicable delays between channels.
(2,958 Views)
