AO Waveform Generation and AI in the same program
Hi All ,
   I gotta generate an exponential sine wave .
i am using the DAQ-Pad-6020E and VB 5 .
Now i am having a serious  problem .
 I downloaded the AO wave form generation program from the NI .Here with i attached the link .
    But when i run this program in my laptop , i see the Blue Screen and got an error message . pls see the attached  error message .
And if you have an exmple program in VB to generate an exponential sine wave , it will be a big hand for me if you can send to me .
I am wholy new using  DAQ and VB .
Suggestions about what i have to learn are proudly welcome .
Thanks in advance .
Aung Myo Thant Sin (indonesia)
http://zone.ni.com/devzone/cda/tut/p/id/3634
A problem has been detected and windows has been shut down to prevent damage to your computer.
The problem seems to be caused by the following file: Nidaq32k.sys
PAGE-FAULT-IN-NONPAGED-AREA
If this is the first time you’ve seen this Stop error screen, restart your computer .If this screen appears again, follow these steps.
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problem continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup options, and then select Safe Mode.
Technical information:
***STOP : 0X00000050 (0XF7B9B032, 0X00000000, 0XAA0947B9, 0X00000000)
***Nidaq32k.sys-Address AA0947B9 base at AA06A000, Date Stamp 40759830
Beginning dump of physical memory
Physical memory dump complete
Contact your system administrator or technical support group for further assistance.
Aung Myo Thant Sin
Candidate - Master of Engineering
Dynamics and Control laboratory
Bandung Institute of Technology
Bandung , Indonesia
Ph : +6285624378664
email : nayaye1@gmail.com
Message 11 of 12
(649 Views)
Hi Aung,
You mentioned that you are using Visual Basic 5 to program your DAQ-Pad-6020E. Are you using Measurement Studio? What driver (Traditional DAQ or DAQmx) and driver version are you using?
I did find that a blue screen is caused by Nidaq32k.SYS with NI-DAQ 6.9.3. See the Knowledge Base article to get more details but this sounds like the same problem you are experiencing. I hope this helps.
Ima
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Message 12 of 12
(634 Views)
