transpose 1d for FP cosmetic issue
Hi there,
This is a dum question but I don't get it. I want to transpose a 1D array (a single column instead of single row). I know that from a Mathematical point of view it doesn't make sense but for my application it does.
Basically I want to display 2 values in column into a listbox
a
b
instead of
a b
Charly
LabVIEW 8.5
It's always sunny in California! Certified LabVIEW Associate Developer!
(3,300 Views)
If you use a single column listbox, you should already be fine.
(I cannot open your attachment. Can you save it as version 8.2?)
(3,298 Views)
Hey Altenbach,
I think a simple listbox is like a spreadsheet you have to transpose the data before pasting them.
I enclosed the same file as version 8.2
Charly
(3,294 Views)
You can just transpose the 2D array ("transpose" from the array palette) before sending it to the listbox or other indicator.
(3,287 Views)
Of course you can also insert your 1D array as a column using "insert into array".
(3,283 Views)
Thank you Altenbach it works great!
Charly
(3,279 Views)
