AI and AO logging
good luck and have fun coding!
Epictetus
Antoine Chalons
Message 11 of 15
(1,310 Views)
Hi Sam,
Thanks for the reply.
As you explined in the 2nd point to write the AOs back to AIs - Is there any way to do this in coding? (I tried to take AO data and give it to AI read DAQmx node but it is expecting the AI input channel to read but not the data from the AO ).
If possible can you please share it.
Siva.
Message 12 of 15
(1,302 Views)
Hi Siva,
you should know the values you're outputing on your AO channels, so just transfer them to your "file write" loop.
Simplest would be to use local variables, notifier(s) are ok too!
Message 13 of 15
(1,295 Views)
Yes - do option 1) that I suggested above. I was merely pointing out that another option is to physically wire your AO back to an AI channel. I pointed out the ways to do this in software (e.g. local variables, notifiers).
(blog)
Message 14 of 15
(1,289 Views)
Sam gets my "thinking out of the box" award for today.
Ben
Message 15 of 15
(1,279 Views)
