03-28-2007 07:57 PM
03-28-2007 09:07 PM
03-28-2007 09:24 PM
03-28-2007 09:39 PM
03-28-2007 10:30 PM
@Dennis Knutson wrote:
Ask them for a programming api (application program interface). Tell them you want to use the hardware with software other than what they provide. If they have a dll, then it would consist of various function calls and you would need this list. Each function call has a set a parameters that you pass to the function and also use to get data back. For example, an A/D device might have a function for setting the sample rate. Call it SetSampleRate. The parameters you have to pass may be an int for device number and a floating point number for sample rate. The documentation for the function would be written something like SetSampleRate(int dev, float rate). If you do get this type of documentation, LabVIEW 8.2 has made it much easier to create the correct Call Library Function Node. This is the LabVIEW function you use to call an external dll.
03-28-2007 11:13 PM
You could do this in LabVIEW. As I said, there is a function called the Call Library Fundtion Node.
Depending on the complexity, it could take a while to write and debug. Using the existing software would probably be more simpler but if you want to read an Excel spreadsheet as its is being written, there might be problems with that as well. For example, the other program may open it exclusivley and you would have to wait until the other program closes it. I now nothing about the other program or what your overall goals are so I am hesitant to recomend one way or another. First, see what the vendor has to say. Worry about which direction you want to take when you knwo whether they will even make their programming interface available to you.
03-26-2014 10:27 AM
Hey,
I am wondering what came out of the powerlab to labview project. I am new to labview and would like to bundle several measurements with it. I would like to buy an EMG/EEG amplifier that I can use via labview and haven't quit decided on a specific one on the other hand I might get a compactDAQ plus small preamplifier.
All the best,
Conni
