ABB ACS880 With modbus communication code
IHai...guys .. currently now I'm doing ABB ACS880 drive coding with Modbus communication.
Can anyone have any refferenced code ND how to give commands to drive.
I can able read the values from drive there is no issue , but I can't able write the commands. While writing commands to drive through Modbus communication in getting errors.
Can anyone help me on this r else can any share code of yours!
Thanks in advance...!!
Sravankumar Atla
CLD || CTD
Message 1 of 8
(8,012 Views)
Hai....Alex...need one help ... I'm doing program for ABB ACS880 drive.can u help me on this...??
Sravankumar Atla
CLD || CTD
Message 2 of 8
(7,995 Views)
Hi Saisravan,
Which errors do you get?
Why should we share our code?
It's your code that gives errors, not ours: attach your code to get help to improve it!
What is this "ND r u" good for?
Message 3 of 8
(7,981 Views)
Thanks your reply...
While writing commands to drive I'm getting errors. Just see the attachment. But I can able to read the values from drive. There is no issue. Only writing commands only problem. Actually my application is lift system.
Sravankumar Atla
CLD || CTD
Message 4 of 8
(7,921 Views)
Hi Saisravan,
apparently there is an error for Modbus function 6. Does your device support function code 6?
Message 5 of 8
(7,895 Views)
Need commands of ABB ACS880 drive
Set Motor start
Set  speed (RPM)
set motor Deacceleration rate
Set Motor Acceleration rate
Set Motor direction
Set Motor stop
Thanks in advance ....!!
Sravankumar Atla
CLD || CTD
Message 6 of 8
(7,880 Views)
Hi Saisravan,
When you want to know the needed commands you need to read the manual of your device!
(I will not do this for you.)
Message 7 of 8
(7,872 Views)
I studied the manual I got few... commands...but those above mentioned commands I didn't got that's why I asked...
Sravankumar Atla
CLD || CTD
Message 8 of 8
(7,861 Views)
