A quite complicated string task
Hello guys!
Today I got into a bit of mess when making a program for my company. I'm reading from a .csv file which is containing information regarding electric components. I have to read the cell into an array for further use. No problem at all.
Now the hard part:
Lets say a cell in the .csv file contained this: C1-C10
I put it into an array and still have: C1-C10
(C1-C10 means there are actually ten cmponents; C1, C2, C3...C10)
I now want to convert the array containing C1-C10 into an array looking like this:
C1
C2
C3
C10
(Se attachment LV2010)
I think a solution is to remove the C from the string and then look at the numbers and find out how many components there are. Then put it back with a C in front and create ten incrementing numbers like this:
C1-C10 => 1-10 = Ten elements => Create numbers: 1,2,3,4,5,6,7,8,9,10 => Add C in front of the numbers.
Anyways this algorithm has to be capable for any letters and numbers, i.e. R2-R5, K2-K7 etc...
Anyone which has done a similar thing and maybe can help me in the right direction on where to start?
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 1 of 11
(6,114 Views)
Accepted by EvenDeejay
Here is my attempt.  I split the string at "-" with Match Pattern and then search each substring for leading letters.  Use the numeric parts to create an array of integers and convert back to strings.
Lynn
Message 2 of 11
(6,086 Views)
Please save your VI in 8.6 and post
Smiley Wink
Message 3 of 11
(6,085 Views)
Here is my VI saved back to LV8.0.  The original VI just had the Array to Spreadsheet String part at the top.
Lynn
Message 4 of 11
(6,078 Views)
Maybe this is Rube Goldberg Code but, here is my version using regular expressions and so on... :
File in LV 8.0.
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
Message 5 of 11
(6,062 Views)
This version corrects a mistake concerning the regular expressions I used.
Da Helmut
Message 6 of 11
(6,052 Views)
This Regular Expression uses a backreference and grouping to extract the letter and start/end numbers; the rest is easy.
Jim
Message 7 of 11
(6,038 Views)
I explained the regular expression here.
Jim
Message 8 of 11
(6,009 Views)
Jim, CLD
Hi Jim,
This is awesome !
Thanks ! I learned a lot today thanks to you and your example.
Da Helmut
Message 9 of 11
(5,998 Views)
You're welcome.  I learned everything I know from the link in my signature and Darin.K.
Jim
Message 10 of 11
(5,992 Views)
