A question about chart
Hi everyone,
i trying to make a chart with a multiple plots.. and there are a few things that I cannot do:
1. I have a multiple plots in one chart, but only one y-Axis (Amplitude). Is there any way so I can get multiple amplitudes (f.E. Temperature and Voltage) ?
2. If that is not possible, I would like to use a LogView program for that task.. I think it would be better solution, but I dont find a way how to put it into my labview program, or even how to connect my program to output the data into LogView...
Do u have any advices?
Thanks in Advance!
Vlado
Message 1 of 8
(3,722 Views)
Picture of what I need
Message 2 of 8
(3,720 Views)
Accepted by vladosaurus
Hi vlado,
1. Yes. As usual the context menu is your friend: right-click the Y axis and select "duplicate scale"…
2. What is "LogView"? Your image is quite blurry, next time please use less JPG compression…
Message 3 of 8
(3,714 Views)
Hi GerdW,
thanks for your tip! It works fine now, and I dont need LogView anymore!
Please, can you also advise me how to change the scala on y-Axis.
I want to be able to see also the numbers between min and max, like on the X-Axis, but it somehow doesnt work..
(see pic)
Thanks once again!
Vlado
Message 4 of 8
(3,684 Views)
Hi vlado,
start with a fresh chart indicator…
Message 5 of 8
(3,668 Views)
Thats exactly what I do, but it still doesnt show the numbers...
Message 6 of 8
(3,665 Views)
Hi vlado,
as soon as I delete your chart and create a new one I can see all axis ticks as needed…
Message 7 of 8
(3,658 Views)
Thanks, i did it as you said Smiley Happy
Message 8 of 8
(3,642 Views)
