A case structure for two inputs (4 cases in total)
Hi all,
I have a cluster that outputs four different parameters as shown in the picture. I want to create a case structure in which I want a different case for + and - values of the I and J (I don't care about X and Y). So how to go about that, I think this is an easy questino for you folks 😄 since I'm a bit noobie here, much appreciated.
Ahmed.
(3,203 Views)
Either nested cases, or use boolean arithmetic
(3,189 Views)
To make things a little more readable, change the case structure radix to binary.
(3,164 Views)
Good idea but this introduces some conflicts because I want discrete cases for +I, -I,+J,-J.
PS: whenever (i.e. I) is nonzero J is zero and vice versa
(3,157 Views)
Accepted by AHmedalnahdi
The same approach, selector can have 9 options, 4 are defined (only one none zero element). Others give error (for example I<0, J>0 will give selector = 9).
(3,140 Views)
Thanks a lot that did the trick .
Ahmed
(3,135 Views)
