A button (or switch) to stop/activate the PWM
I have a project I am working on and everything is finished the only thing I have left is that I need to add a button (or switch) to stop/activate the PWM. I feel like I have tried everything, case structor around everything inside the while loop, case structor around the LED, now I am trying to solve it with a select block but it seems like all it is doing is slowing down the LED for a bit. Any advice?
Best Regards,
Nick
(2,051 Views)
Okey, I am not sure how to remove the question but I solved it
(2,012 Views)
Hi Nick,
instead of deleting the question you should provide the solution!
This is how this forum works...
(2,007 Views)
Thanks, for the answer.
So I used a selector block which I spoke of before but instead of connecting a button I used a switch.
In the file you can se how I did it.
Best,
Carl
(2,003 Views)
Now you want to simplify your code. Is it way more complicated than in should be.
  • If the cleanup button significantly improves the look of the diagram, your code layout was very poor.
  • To toggle between 0 and 1 with each iteration, all you need is a bitwise AND of the iteration terminal with 1. (eliminating your case structure, "+1", shift register, etc.)
  • Your lower case structure contains duplicate shared code (e.g. the wait) that belongs after the structure as one instance.
  • Try to do your math on integers. There should be no blue wires anywhere.
  • Make the pause switch to be False if paused and just AND it with the PWM result.
  • You can eliminate the NOT by swapping the constant values inside the case.
  • Give your terminals reasonable names ("Numeric Control", "string", and "Boolean" are not reasonable labels)
  • etc.
(1,994 Views)
You might want to re-think the entire approach and use a loop with a fixed loop time and just toggle based percentage. With your design, you can easily get into log wait where the controls can react very slowly to user interactions.
Here's a "literal translation" of your code to give you some ideas about the points I made above, but you should really redesign it from scratch.
(1,981 Views)
