98% duty cycle on NI myDAQ using LabVIEW?
I'm trying to output a square wave with frequency 100Hz and a duty cycle of 98% but when I do this with labview I just read a flat 5v's and don't see any edges. I can output the square wave using NI ELVIS(and having it work) so I figure it should be doable with labview. Any sudjestions on how to make this work would be great thanks. I will atach my vi file.
Message 1 of 11
(8,884 Views)
Your attached VI shows a DAQ Assistant with no input device wired.  Are you not using the NI ELVISmx library for your myDAQ device?
Message 2 of 11
(8,842 Views)
Uhmmmmm...Smiley Embarassed
you have a 1000 sample per second task with 100 samples being written.
Lets just check this box and make it a bit simpler:
"Should be" isn't "Is" -Jay
Message 3 of 11
(8,835 Views)
Alright I have the box checked now.
Message 4 of 11
(8,828 Views)
I'm using an external oscilloscope to measure the output and I belive I'm using the NI ELVIS mx libary.
Message 5 of 11
(8,826 Views)
When you enter the duty cycle, be sure and enter it as 0.98, not 98.  You can add a Waveform Graph indicator and you can see what the signal out should look like.
Message 6 of 11
(8,814 Views)
Alright I tried the .98 and put it on the graph this is what I get.
Message 7 of 11
(8,808 Views)
If this would be easyier to do using a digital output I would be open to that method aswell.
Message 8 of 11
(8,805 Views)
Something is clearly wrong.  What happens if you use 0.5 and 50?  Do either of them look like 50%?  If so, that tells you where the decimal point goes.  Then you can try 75%, 85%, 90% to see where it breaks down.  When you have the answers, post them, along with your current code (please post the VI, not a picture).
Message 9 of 11
(8,791 Views)
Okay so I have something that appears to work but I feel as theres probably a more elegent way of preforming it
here is the output.
Message 10 of 11
(8,787 Views)
