7 segment
Dear all,
Got Labview 7 and i try to display a number on a 7 segment display (like 458) im new to labview
and i already look for hours to find an example but did not find it.
The display should have 5 7segment display, can someone help me ?
Greetings
Drek1234
Message 1 of 26
(7,116 Views)
Have you found examples for doing a single 7 segment display?  Take those and expand them for any additional displays you need.  And if you tell me you couldn't find an example, then you did not look.  There are a ton of them here on the forums.
Message 2 of 26
(7,115 Views)
Right but all examples a for higher versions i think i tried them all, with  a good example i good do much
Message 3 of 26
(7,111 Views)
They will likely be written in higher versions, but what you need has not changed since then.  You will just need to put forth the effort to write it yourself.  If you run into issues, post what you have so far and we can help guide you through it.
Message 4 of 26
(7,102 Views)
dont kill me if you see this 🙂 got an rs232 from a balance the weight on the display of the balance i wanna get
in labview on these 7 segment display's
Message 5 of 26
(7,094 Views)
Do yourself a favor and make your 7 segment dispaly a cluster.  Then you can copy that cluster simply and write the entire cluster instead of the individual lines.  I'll make your life a lot simpler.
There are several subVIs missing, so I can't see what your number to 7 segment VI looks like, but at least you made a VI specifically for that.
Message 6 of 26
(7,087 Views)
" your number to 7 segment VI " thats just the problem, i got the number but dont know how to convert it to 7 segemnet
Message 7 of 26
(7,055 Views)
Search the forums for "7 segment" and you'll find some code that will help.  There was even a recent thread discussing this that will point you in the right direction.
Message 8 of 26
(7,030 Views)
I'll even help by providing a link: http://forums.ni.com/t5/LabVIEW/7-segment-display/m-p/2842206#M830033
Message 9 of 26
(7,016 Views)
Message 10 of 26
(7,015 Views)
