6503 Examples
Not sure what Im doing wrong but I cant seem to find example code of how to control a dio-24 6503 card.  Ive got max installed and the test panel works but when I load up labview 8.6 I cant seem to locate anything that tells me how to communicate to this card or control the bits.
What I need is very simple toggleing of 2 bits.
(3,539 Views)
Accepted by ggravert
Help>Find Examples and when the example finder opens, select the PCI-6503 in the hardware box in the lower left by clicking the 'Add Device option and then click the 'Limit results to hardware'. There's only a couple that you really need to look at - 'Write Dig Chan' and 'Write Dig Port'.
(3,533 Views)
Hi ggravert:
Which version of Max you installed previously? Might be LabVIEW 8.6 doesn't support that driver. I have LabVIEW 8 & Max versio 4.0. Here, I made basic vi for toggleing 2 bits.
If you have any doubts then let me know.
(3,529 Views)
