6320 slow ADC read
I am using a PCIe-6320 that I am polling the ADC, in a very simple while loop.  The time per iteration of the while loop is approx. 9 millisec. While the interation time of the while loop without reading the DAC is 10 microseconds. That is huge difference.  Any thoughts, I am trying to poll at about 4 kilohertz which I would think would not be a problem.  BTW I am only reading one channel.
Mike
(3,229 Views)
Mike,
Are you calling DAQmx Start prior to the loop which performs your read?
Dan
(3,225 Views)
Besides reading only one channel, how are you reading it. If you doing something like 1 sample mode, then you are doing software timed acquisition and that is very slow. If you are doing continuous acquisition, then your loop rate is a function of your sample rate and the number of samples. It's simple arithmetic.
(3,220 Views)
Yes
(3,208 Views)
Accepted by topic author mwalczak5603
Software, let me give harware timed a try.  Thanks.  It just seems so odd that just doing a simple read would take so long.
(3,207 Views)
One other thing that you may want to try for your software timed task.  In the DAQmx Channel Property Node, navigate to Analog Input->General Properties->Advanced->Data Transfer And Memory->Memory Mapping for Programmed IO Enable.  Set this property to true.
Dan
(3,203 Views)
That's cool I will try that too.
(3,200 Views)
