5671error
First of all, happy new year :-)...
I  have the following problem:
My upconverter (5610) will not pair anymore with my AWG 5441. The two PXI cards were calibrated not long ago and afterwards they wouldn't pair anymore. I tried several options like,
reinstalling the drivers, removing the cards and deleting them in MAX and again reinstalling them. This all did not work.
Then if i look within MAX at the 5610 and try to start the testpanel the program opens but wil not run, when pressing the run button the following error appears: see picture...
i search on the files that seem to give the problem but they are working properly...
Frankly  I don't want to reinstall everything....
Can somebody help me?
Best regards
Joost
(3,039 Views)
Accepted by topic author Naturalarch
Those are problems are not related to the instrument. The message is saying that some of the VIs making up the test panel in MAX are missing. Have you installed, removed or modified any of the software on yur computer recently?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,033 Views)
Hee Mike,
The new software i have installed is a new modulation toolbox and after that the GPS toolbox. But the error was allready present before that. What i now tried after your remarks is to update de NI DAQ driver from 8.7.1 to 8.8 Because this seems to install an update of MAX also, but this still didn't help...
Are there any more suggestions?
Best regards
Joost
(3,004 Views)
