5133 - buffer reading
I have a 5133 and I need to read 1024 Samples (rate 100MS/s) on a HW trigger. The trigger frequency is 3600Hz and I received the trigger for 2 seconds.
I have to acquire 1024*3600*2=7372800 Samples. I don't Know how to do...
(3,196 Views)
I explain better...
I want to know if I can do something like the "MULTIPLE RECORDS"
(3,186 Views)
Hello Fabio,
I think you have to take a look at the following two examples.
NI-DAQmx: Acquire Analog Input Data Using a Hardware Analog Trigger
https://www.ni.com/en/support/documentation/supplemental/21/ni-daqmx-data-acquisition-triggering-tec...
Acquire & Graph Voltage-Internal Clock-Hardware Trigger Restarts (finite amount of data)
https://forums.ni.com/t5/NI-DAQmx-Examples/Acquire-Graph-Voltage-Internal-Clock-Hardware-Trigger-Res...
Continuous Acquire and Graph Voltage Internal Clock With Analog Start Trigger (continuous data
https://forums.ni.com/t5/NI-DAQmx-Examples/Continuous-Acquire-and-Graph-Voltage-Internal-Clock-With-...
Antonios
(3,165 Views)
I'm not able to use daqmx functions... I can use only NISCOPE....
After that, for the first link I think that the solution doesn't match my request, the other two can be... but I think we are to slowly.
(3,153 Views)
