4X4 Array within Intensity Graph
On the Insity graph I can see Analogue Input 0/ Voltage_0 (showing the 8 values on the pins y0-y7 of the 4051 multiplexer ). Now I want to see Analogue Input 1/ Voltage_1 (showing the other 8 values on the pins y0-y7 on the second 5051 multiplexer)
Message 21 of 26
(1,055 Views)
^^^Again, if you can show me how to do this I would be extremely grateful!^^^^^
Message 22 of 26
(1,054 Views)
Hi HEAPO8,
I'm not really clear what the issue you are now having is.
If you wouldn't mind, could you post your latest code with a brief explanation of the problem?
That would help me, and other community members quite a bit.
Kind regards,
Josh E
Applications Engineer
National Instruments UK & Ireland
Message 23 of 26
(1,034 Views)
Things are a bit scattered. According to this statement, this particular issues seems to be solved.
Message 24 of 26
(1,028 Views)
Hi altenbach, would just like to say this issue has been resolved and I have been able to interpolate my readings. Just would like to know how the example works, in depth. Although it has worked, i would like to knowhow it it works. You provided a brief explination, just wanted to know whether you can go into further detail? thank you
Message 25 of 26
(1,003 Views)
^^^sorry wrong thread^^^^
Message 26 of 26
(999 Views)
