4-20 mA measurement with NI 6009
is it possible to connect a 4-20 mA sensor with NI-6009 and read the values with labview interface ?
Thank you
(993 Views)
Yes, by using a precision resistor of 250 Ohm and 200mW or higher. The usual resistor you can normally buy is 249 Ohm +- 1 % or better. Measure the voltage over the resistor, divide by 249 and you get the current. Scale to whatever physical unit your sensor uses according to its calibration data.
Rolf Kalbermatter
My Blog
(988 Views)
Yes,your principle is right.Can someone share a schematic for measured current,thanks!!
(897 Views)
TT-12-A-768x306
Santhosh
Soliton Technologies
(892 Views)
Got it,thank you so much for you prompt replied.
(884 Views)
