3rd boolean is not displaying up the graph
hello,
in the VI with every Boolean selection the corresponding measurement is happening and hence displaying the graph but the 3rd Boolean case is not executing .can anyone help me in this?
Message 1 of 9
(4,548 Views)
Not able to View your code, Try sharing the lower version of code[Running with LV 2017]
Message 2 of 9
(4,542 Views)
Message 3 of 9
(4,536 Views)
All three Values in the graph with the same VI you attached
Existing code should be modified (Preferably to State machine Architecture)
Message 4 of 9
(4,521 Views)
@PALANIVLT,
HI
the first and second one s working accordingly but when the 3rd boolean is (T) selected then every graph (previous)coming all along.
also just selecting the 3rd boolean is not giving any data which is not the case withh the other two
Message 5 of 9
(4,518 Views)
Accepted by jyot445
The way you coded is not the proper way of coding
The problem you are facing is "in you are feeding the Array of your second sequence values which is empty"
For Loop will iterate with minimum N Values/Index Elements so its yon execting
Message 6 of 9
(4,510 Views)
Find the attached Modified code.
Message 7 of 9
(4,504 Views)
@palanivlt
thanks a lot,i got to know to know a more easier way to do the same work.
Message 8 of 9
(4,491 Views)
helo,
the same problem coming with this vi
Message 9 of 9
(4,437 Views)
