3d rotation
I would like to rotate the two objects in this .vi independently of one another in the x and y directions. However, the objects rotate in only one direction despite that two angles are specified. Please help. Thank you.
(2,591 Views)
Read the context help for rotate object.  It says:
"Clears any rotations previously applied to an object ..."
(2,580 Views)
According to the help, "set rotation" clear all previously applied rotations, meaning the second instance clears the first rotation. You should use "rotate object" instead.
(2,578 Views)
