3d plot z scaling
An aplication we're developing utilizes the 3D Surface.vi to plot a surface. However, I'm unable to come up with a way to controle the z scaling programmatically by property node or by other means. In addition, it would be nice if anyone has a way to generate a cursor that reads out the z value on the surface.
Thanks.
Devon
Wavefront Sciences, Inc.
LV 7.1
(2,623 Views)
The attached ZIP should get you started.
The top level VI labeled "3-d Surfaace.VI"
explicitly sets the scale ranges in the sub VI Set Axis Range
and creates two cursors. The second of which can be used to probe the suface.
I hope this helps,
Ben
Message Edited by Ben on 10-22-2005 08:22 PM
(2,612 Views)
