3d plot axis marker goes into graph
Hi All - when I run scans in a 3d plot, with autoscaling enabled, the problem shown in the attached figure presents itself - the font goes into the fluorescence (Z) axis. Is there some easy way to avoid this? I suppose I can change the font size, but this seems like something that should be done automatically by labview. Thanks.
(2,930 Views)
There must be some way of automatically moving the font - if I enter the 3d plot properties dialog, and select axis, it is as if the plot "refreshes" and decides to move the text over to a proper spot further to the left.
(2,927 Views)
Ok, a workaround - making the marker visible & immediately revisible (property nodes) ensures correct placement. Of course, you're stuck with an ugly flicker every time you update the plot which sucks if you're doing it in real-time like I am.
(2,922 Views)
Does defering panel updates help with the flicker on these graphs?  I dont think it did with the old, better, cw3dgraphs if memory serves.
Tim Elsey
Certified LabVIEW Architect
(2,917 Views)
