3d picture property node bug?
I've noticed somethings recently that seems odd and may be a bug or may be intended (but still kind of quirky) behaviour.
It's apparently not possible to have a property node for a 3d picture linked via a reference to a 3d picture.  Each property node needs to be intrinsically tied to a specific control or indicator.
Attaching up a 3D picture reference to a property or invoke node yields no methods and no properties yet property nodes and invoke nodes can be created by right-clicking on the terminal and choosing them directly.
Any ideas why this is so?
I've observed this in LV 2011 and 2012.
Normally we only have a single entry for property nodes or invoke nodes whereas here we have two as if Lv acn't decide what object type the 3d picture is.....
Shane.
(3,665 Views)
I am confused.
Your image shows the option to create reference just above your green outline.
What am I missing that you are looking to find?
Ben
(3,635 Views)
The green region gives you the option to Create a Reference, Property Node, or Invoke Node for the control which happens to be a RefNum control.  The red region gives you the normal menu you are looking for.
Same thing happens for all reference controls, VI refs, .NET, etc.
(3,631 Views)
