3d graph plot from .txt
Hi
I have some .txt datas which I want to visualize. I need one of the wavelenght columns as x axis; and the last column OE1_Channel1 as z axis. Last I have ~100 .txt which should build the y axis.
I dont know how to go on, "delete from array" seems to be not enough, and I have no idea how to build this plot from several .txts
(4,570 Views)
oh here is a example of the .txt
(4,565 Views)
This is what I did befor, but I haven´t discovered yet how to make one row the y axis and how to make several txts the x axis.
(4,563 Views)
ok, i got it, but I still have a question:
can I automatize the input, I still have to load every file manually?
(4,559 Views)
Robert,
I had a look at your code but I really can't match your question with your vis. To answer your question: Use the file I/O functions to load data from files but this doesn't seem to be related to your code...
Jochen Klier
National Instruments Germany
(4,538 Views)
Thanks, but I got it myself. Slowly but surely I solve my problems alone.
(4,534 Views)
Hi Robert
I've developed a little utility called 3D Viewer that should do what you want.
You can download and evaluate it from my website.
www.sciware.com.au
Kurt Friday
www.sciware.com.au
(4,518 Views)
