3D vector plot
I am performing a CNC machine tool capability study.  I have measured a vertical, 3 axis (x,y,z) milling machine in all three axes using a laser measurement system.  The data I have recorded is target position vs actual machine position.  A good way of representing this data would in a 3D vector plot.
I have had a play with the 3D line graph but I am struggling to achieve what I require.  Please see attached image as an example of would I require.
Is this style vector plot achievable in LabVIEW? Can someone make a suggestion of what plot/graph to use?
Tom
(7,102 Views)
Search for "quiver Plot" in the LV examples.
Ben
(7,097 Views)
Hi Ben,
Thanks for the prompt response.
I cannot find an example of a quiver plot in the examples.....I have LV 8.5, is this plot available on this vesion?
Tom
(7,095 Views)
The quiver plot is introduced in LV2009.
(7,088 Views)
...then in that case...
Christian Aletenbach posted an example of drendering arrows in 2D SOMEWHERE on this forum. Unfortunately I did not tag the post so it will require a search.
His math can be extended to 3D to get the arrows. Each arrows can be a seperate plot in the 3D graph.
Take care,
Ben
(7,078 Views)
Ben,
This is the link to Christians post - http://forums.ni.com/t5/LabVIEW/2D-Vector-Plot/td-p/192478
I'm not too sure how this can be modified for 3D, is it easy to adapt the 3D quiver plot example?
(7,061 Views)
