3D surface plot FillColor property node misinterpreting colorbox
Hello there,
I'm using the 3D parametric surface VI to plot a single data set.  When I wire a colorbox to the FillColor property the 3D plot interprets green somewhat correctly but a selection of blue in the color box makes the plot orange and a selection of red makes the plot blue.  The colors don't match up across most of the spectrum.  Somehow the colorbox is being misinterpreted but I can't find any reason for it.  I tried converting the U32 to different integer types and that didn't help.  Any input would be appreciated.  Thanks!  (Please see attached JPG)
Ethan
(3,009 Views)
LV uses RGB colors.
CW uses BGR colors.
Break the U32 into its bytes and swap the R and B values.
See this thread for an example.
Ben
(3,004 Views)
Piece of cake.  Thanks Ben!
(3,000 Views)
