3D surface blinking problem
When I am working with the CWgraph3D control, I met another problem.
Say, I am plotting a surface with given x, y and z vectors. The vectors are changing every time in a loop. I have the plot showed right but it is just blinking (due to the fact that I "remove all" plots every time before I plot new things in the 3D control). I wonder how can I solve this problem to have a smooth display?
FYI, I am giving the x, y and z vectors from 3 points (P1, P2, P3) in real time moving; So I want to keep trace of motion of the surface which created by the 3 points.
I have attached an example.  Thank you for you help.
Regards.
(3,353 Views)
Did you try not delting all and just updating theplot numbrs yu are using?
Ben
(3,331 Views)
I have this same problem. I create a number of 3D plots using CWPlot3D, Plot3DCurve, that are added together (using CWPlots3D, Add). Every iteration requires a 'RemoveAll'. This causes the plot to start blinking.
I'm new to LabView, so Ben's answer does not mean much to me.
Is it possible to prevent this blinking?
(3,021 Views)
You have more problems than that!
You just replied to a 6 year old post!
Go ahead and start a new thread (feel free to provide a link to this old post) and attach the code you have so we can help you better.
"Should be" isn't "Is" -Jay
(3,019 Views)
