3D plane using four points.
Can I build a 3d PLANE using 4 points with Labview 6i and how?
(3,344 Views)
There's a 3D surface example called "Flucuating Sine Wave.vi" that should point you in the right direction. What exactly are you wanting to plot?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,344 Views)
Hi Mikeporter, thank you very much for your help. In which vi library can I find the "Fluctuating Sine Wave.vi"? I would actually like to represent a pyramid in 3 dimensions.
Summer
(3,344 Views)
In LabVIEW go to the examples browser and click on Fundamentals, then Graphing and finally the first selection is 3D surface plot.
Mike...
LabVIEW Champion
(3,344 Views)
Thank you very much for your help.
Summer
(3,344 Views)
